TeleFragger
- Nov 10, 2005
Ok so I tore apart a Dell xps to try and stuff into a short rack case and was a no go. Anyway I have my mobo im going to use setup and it has 6 fan connectors for 4 pin fans.
Dell fans have long cables so wanted to use them as they too are 4 wire... plugs in and looks fine but im wondering if I can shuffle the wires around. The Dell has the black connector ends vs the standard white plug.
I know I know buy new fans... trying to recycle what i have before they go into the trash plus I have 2 60mm fans that seem to pump put some air and are the thick style fans...
anyway help the fan n00b out please..
google is showing this.. work is blocking the link but in google search im seeing it so hope it shows here.. wondering if i just change the wires around...
https://www.google.com/url?sa=i&rct...GhS_OdHVXiT_p8gLO-r1ZSkA&ust=1443871380599345
