I tried searching for an answer but kept getting too much other stuff like questions on the difference between a 20 and a 24 pin connector for a mobo and stuff.
I'm nearly ready to turn on the power to my Gigabyte DS3 with Conroe and I have the PSU connected to the mobo with the 24 pin connector and I also have the separate 4 pin 12 volt connected to an area near the cpu, from what I read to it's to power the cpu mainly.
My question is, are you still suppose to use that separate 4pin 12v connector if you already use a 24 pin main poewr cable? I was just worried that maybe with a 24pin connection you wouldn't need the separate 4 pin 12v connector, but from what I've read it seems like you are suppose to do both.
So is that right, connecting the 24 pin main cable and the separate 4pin 12v cable is correct?
