thecomputeraddict
- Apr 27, 2008
If you had 4 gigs of ram in your computer running ultimate, would using an 8 gig flash drive for ready boost free up most of it?
"Utilize" would be the better choice of words
You spent hard earned $$ on that RAM! You don't want it to go un-used, do you?
Superfetch analyzes your computer usage and preloads frequently accessed blocks of data into RAM. It will use (IIRC) up to 50% of your available un-used memory.
http://www.microsoft.com/windows/windows-vista/features/performance.aspx
Windows SuperFetch
A new memory management technology in Windows Vista, Windows SuperFetch, helps keep the computer consistently responsive to your programs by making better use of the computer's RAM. Windows SuperFetch prioritizes the programs you're currently using over background tasks and adapts to the way you work by tracking the programs you use most often and preloading these into memory. With SuperFetch, background tasks still run when the computer is idle. However, when the background task is finished, SuperFetch repopulates system memory with the data you were working with before the background task ran. Now, when you return to your desk, your programs will continue to run as efficiently as they did before you left.
Technology like Superfetch is why Vista is so responsive compared to other OS's like WinXP.
We all need to get past the old mindset that less is more.
If you have 4 GB of memory, you want to use it, right?
You don't try to keep your gas tank as low as possible, do you? Ideally, it'd be forever full![]()
