demografik
- Mar 25, 2002
I'm really unhappy with the Gigabyte GA-7N400. I had to RMA my first one because when I installed it, I didn't realize I couldn't boot from my hard drive with a new motherboard. I didn't want to format, so I put my 8kha+ back in to try to find out how to replace a motherboard without formatting. After I figured out what I should do, I put the board back in, BAM doesn't work. LED's come on, fans start up; no bios beep or post.
So today I got the new one. Now I know what I need to do to install it without having to format. So I carefully and slowly set everything up. I fire it up, everything works great. Just need to set to boot from cd-rom to boot with the w2k cd and repair. While I'm in the bios, I check my temps. The cpu reads high, around 70c. I quickly turn it off to take it out. I look at the cpu, looks like the problem was too much thermal grease. I apply a thinner layer and go to turn the computer back on. At first I get a really weird low-pitched siren type sound from the bios and it shuts itself off. Then I turn it back on and guess what..back to the same problem I had with the first one. GREAT! I've tried resetting cmos, unplugged all cards, IDE devices, unplugging the power and activity LED's, even using a seperate power supply for the fan on my heatsink as it's a delta 8k rpm that eats up alot of power. Also reseated the cpu and heatsink repetedly. Still nothing.
Here are my specs:
Athlon 2500+
Corsair 512mb xms2700
Antec 300watt psu
Radeon 8500
Maxtor 40gb
Right now I'm using a machine i put together with my old 8kha+, 2500+, hard drive and video card. Basically I just put it all into another case with a 200watt power supply. Help please?
Here are my specs:
Athlon 2500+
Antec 300watt psu
Radeon 8500
Maxtor 40gb
