Reading Word Documents without Word installed
KingKaeru
Hi Guys,
I need to extract text from a word document on systems that do not have Word installed. Does anyone know of any libraries that will do this?
Looking to use c#
Thanks,
--KK
There is also wvWare for converting Word docs to other formats... might be useful for someone.
wv is a library which allows access to Microsoft Word files. It can load and parse Word 2000, 97, 95 and 6 file formats. (These are the file formats known internally as Word 9, 8, 7 and 6.) There is some support for reading earlier formats as well: Word 2 docs are converted to plaintext.
wv compiles and works under most operating systems. Although most development is carried out with Linux, wv should work on BSD, Solaris, OS/2, AIX, OSF1, and even (with varying levels of success) AmigaOS VMS. The GnuWin32 project maintains a port for Windows, and it is required to compile and work on all of AbiWord's supported platforms, of which there are a lot.
wv allows other programs access to Word documents for the purpose of converting them to other formats. It is currently being used by AbiWord as its Word importer, and concepts and bits of code are being used by the KDE folks over at KWord in their word importer.
Well Microsoft offers Word Viewer. It opens any word document (through Office 2003) just as Word would. It will open it but you can't modify it. You can cut and paste from it.
I think KK wanted to get programatic access to the content; programs like Word Viewer don't help with that.
Opps, you are right.
I must have only read the title.
