Reading multiple external drives as one drive in XP?
dalfiuss
I have a few external drives on an old computer that I set up as a media server. The problem I have is in the organization of the media spanning 3 drives. I simply want to be able to read those three drives as one for the sake of more streamlined file hierarchy.
I don't care about any data redundancy or fast speeds, I just need something like Logical Volumes in Linux.
Are you able to use USB disks with XP's Dynamic Disk? Or is there any other solution (even 3rd party) that allows for these physical drives to be looked at as a single logical drive within the system?
Any help would be greatly appreciated!
Ahh, left part out. The drives were originally formatted as HFS+ on my MBP and are being read with Macdrive, so I am not able to convert them to a dynamic disk.
Before I begin the process of shifting data in order to format them and try it out I wanted to know if it was possible.
JBOD would require a raid controller, would it not? My PC currently does not have one.
I am considering getting an enclosure that handles JBOD internally on two drives, does anyone know if you could then mount that individual logical disk as a folder on another drive?
So for example, with two of those enclosures, 4 drives would appear as 2, and then those two drives could simply be mapped as folders within my main drive?
Software JBOD (ie Using dynamic disks) would do this but you will need to re-partition the drives.
Personally I wouldn't suggest doing this, there seems to be a large margin for error. I would suggest placing the drives inside your media server and then using Dynamic disks and a stripe if possible or JBOD if not.
