Reading from SD card... save battery life?
HardD99
Sorry, I tried searching, but I really couldn't think of the search terms for this question, lol.
Ok, so the thing is, I was thinking about purchasing a large SDHC card to run movies from on my laptop for plane rides and such to save battery life. The reasoning behind this was that I could possibly save some battery life by not using the hard drive, but I'm not exactly sure how that would work. Would the hard drive still be accessed, or could this potentially save me some battery life?
2GB RAM, 120 GB Hard Drive, Vista Business <-- If this makes any difference.
Thanks guys.
It's not going to save much battery life if any running it off a SD card as oppose to the HDD. What makes a difference is to dim the brightness level of the LCD, using headphones as oppose to the built in speakers on the notebook, playing movies off the HDD as oppose to a CD/DVD drive. Turn off the wireless feature on the notebook, have your HDD defragged so it spends less time searching for all the data, shut down any programs that may be running in the background. Also, make sure you do not have an USB devices plugged into the notebook as it consumes power.
Thanks guys.
Also go into the power options and change the maximum processor speed to a percentage that won't cause movies to lag like 50%. That will greatly increase battery life.
Thanks HardwareGuru & CptFalcon, I never thought about making sure the HDD is defragged. And I have played around the cpu speed, but good idea about making sure it doesnt lag the movies, hehe.
So, the consensus is that the SD card will use as much power as the HDD, or that the HDD will continue to be used while also using the SD card?
Yah, the HDD is still in use when it's reading off the SD card. Reading off a SD card is slower than reading it off a HDD. I wouldn't want to play movies off a SD card. I tried that with my 4gig SDHC playing videos I capture on my digital camera at 848 x 480 res. Depending on what pc I am on, it would stutter trying to read it off the card. But, plays just fine when it's saved on the HDD. From what we just mentioned earlier, those factors contribute more into conserving battery life.
