Emission
- Dec 6, 2005
Hey guys! I'm back again, and this time I'm getting an itch for some cold clocking action .
11/1 Update:
I'm doing the magic with an E4500 as opposed to a Celeron 440, reasons are stated in the update post.
I have a case and a power supply for this system already, so I'm left with choosing the pieces for the rest of the system. I'm already decided on the memory and the GPU, now I'm considering my CPU/Mobo choices. The system so far is as follows:
PSU: Corsair VX450W - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
Memory: Mushkin 2x1GB DDR2 800 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820146118
GPU: Foxconn 8600GT-256 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814186023
Possible CPU: C2D E4500 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115031
Possible Motherboard: ASUS P5K SE - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131189
Cooler: Vigor Gaming CLT-M2I - http://www.newegg.com/Product/Product.aspx?Item=N82E16835702002
The cooler above was strategically chosen to give me the greatest headroom with the least headaches. I can probably pull some amazing results with it, which is exactly the reason why it's my choice.
The last thing I really need are some evaluations on my CPU/Mobo choices, moreso the motherboard. I need a hint as to just how capable it will be.
Lastly, the case: Rosewill R330-P-BK - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147077
I love this case, as it's one of the most well built cases I've ever owned, which is a *lot* to say for this price. I would just like a couple ideas as to what I could do in terms of a mod. It doesn't really call for one but I figure that it would be cool to do something to it. And if I mess up it's no big loss, I'll just get another and continue modding .
Lemme know what you guys think!
- 1/10/08 Update -
I've recently picked up a little pocket change and ordered some parts. The parts I ordered are a bit different than the original list, and I'm starting out a little smaller in terms of cooling compared to the original plan, but I'm saving up a little more for a watercooling setup.
- C2D E4500
- AC Freezer 7 Pro
- DFI P35-T2RL Blood Iron
- Transcend JM800QLU-2G 2GB DDR2 800
- Hitachi 400GB 7200RPM SATA
- Asus EN8800GT + Zalman VF900CU
I'll post a little more on this later.
11/1 Update:
- 1/10/08 Update -
- C2D E4500
- AC Freezer 7 Pro
