Every time I apply thermal paste I feel that I mess up somehow. The first time I tried the "pea" method but because some paste kept coming out of the syringe after I stopped pressing, it left a little line trailing to the right of the dot, and it and caused the round dot to become slightly stretched/elongated to the right. Also I failed to align the heatsink properly on the first try, so I had to lift it slightly after I had pushed it down onto the CPU, which may have created air bubbles.
So after a few days I decided to clean and re-apply the thermal paste.and try the "X" method this time. This time I messed up a little and the center of the X ended up off-center (slightly too far down), which is obviously not good since the CPU die is in the center.
Temps seem to be about the same, maybe 1-2C higher now, but it's hard to tell because the weather keeps changing from day to day. Should I give it another try or just leave it as is? Some say they gain about 5-10C by getting a really good TIM footprint...which would certainly come in handy (pushing ~85C in Prime95 Small FFT's at 4.3 GHz/1.2V). It's just so hard compared to the videos where they just dab some onto the, install the heatsink and when they take it off they have a perfect, smooth layer. Wonder how many takes they do before it looks like that...
