RDRAM Cooling..
jond102
Ok I've had no problems getting my 2.4C 533fsb processor and single 512 1066mhz dual channel Rdram stick to a stable 160fsb. Today I installed a second 512 stick and it's hardly stable at 140fsb.... My temperature went from 35*C load non-OC'd to 45*C..
A large drop to say the least. Also because of the latency issues with RDRAM i want to be able to clock it up as fast as possible to get the total latency under 100ns, which is acceptable I guess since I mostly play mmorpg's.
Anyhow, I was wondering what's the best way to get these sticks cooled down. I need something, I've lost a lot of speed to double the ram.
http://usa.asus.com/products/mb/socket478/p4t533/p4t533_l.jpg
The CPU fan sucks in and blows out right onto the ram, and the oposite side. The cpu fan is a thermaltake copper running at 6100rpm.
PS, I see that other thread so don't get on me bout that =)... these are just a different size etc, and all the products I see only fit DDR modules.
RDRAM is very finicky, so there's a good chance your stick is maxxed out. I don't remember the details on i850/E chipsets, but if the RAM and FSB are linked (as they most likely are), a 160FSB requires PC1280 RDRAM- consider yourself lucky that ONE of your sticks handles it, considering the scarcity of PC1200 and (near) non-existence of PC1333.
The stick that is limiting you is running PC1120, so I doubt extra cooling will get you up to that next speed grade.
OH!!!!!!!!!! i *loved* that motherboard, bought it when it just came out... mmm... P4T533... sold it to a german dude on ebay a year later, missed it... sorry, offtopic a bit... did you know it was featured in Maximum PC's Rig of the Year?... 2003, i think?... as the most eclectic choice EVAH.
now... just mount a fan above the memory sticks, blowing on them. make an aluminium bracket. should be very straight forward.
there are no heatsink replacements for that RAM, since it's riveted to the stick's PCB.
in any case, i doubt you'll be able to achieve very high overclock with that RAM, as it is indeed very phinicky.
Both sticks running stable now after over 4 hours of WoW gameplay on max res and graphics. The clock is at 160mhz, but I did have to use a larger fan with a little bit of bendable rubber tube to blow all that air right onto the ram *smiles*
Maybe I'll be able to come up with a more conventional way to keep it cool, but it seems like that with enough it'll be fine. The latency is down to 96ns now... i figure that's alright considering the bandwidth i'm getting with it.
