Demon10000
- Aug 20, 2006
What do you guys use for RDP management? I use Visionapp Remote Desktop and it is a great piece of software. I'm just putting feelers out to see if there are any competitors to this application that might be worth looking into.
If you manage multiple windows servers, and you don't use a software package like this, you should definitely check it out. It makes managing RDP sessions to multiple services a snap!
VRD has it's quirk, but it gets the job done. It's the only software of its kind that I've seen, and I'd love to try others to see how it compares. I think my favorite feature is assigning credentials to a node, and then being able to right click on a node of servers and log into them all at the same time. Saves a lot of time when you have to log into 200 servers!
I saw RoyalTS, and I'm looking at this one now...
