RCA Wireless Headphones $19.99
annaconda
RadioShack has RCA wireless headphones for $19.99. Free Shipping $50+.
Free after $10 rebate Memorex Jewel Cases. Catalog # 26-1639
Link
Dang I just bought some openboxed AR ones yesterday for $10. I may get this anyways. I like Radio Shack stuff. Anyone used these before?
A lot of the in car TVs use IR for the headphones. Whenever taking my daughter on a trip I have a pair of these packed and make sure the rental has the TV.
Considering picking these up... going to look for reviews first. I guess they can't be that bad.
EDIT: Google found these on Amazon. As expected, Amazon has plenty of reviews for this product. Nothing professional, bit it's better than not knowing what you're getting!
Alright, I picked a pair up.
Initially the headphones had a pretty loud hissing, which I expected to go away once the signal started transmitting. Unfortunately... no. They still his. However, if you turn it up loud enough, you can just barely make out the hissing sound in the background. Sound quality isn't that great, but they get the job done.
For $20 I'm satisfied, especiall since they came with the rechargable batteries. I wouldn't be happy if they were $40. I'd say jump on this one right away if you need wireless headphones. If you just need plain headphones, skip these. The hissing makes them inferior to just about any other headphones.
EDIT: I lied about the static. It must be my sound card.
Well my static problem with the sound card seems to be solved. Like expected, the wireless still have a small amount of static. But that's only really noticable with nothing playing. At this point I'm VERY pleased with them. Recommended to anyone that is in the market for wireless headphones but doesn't need exceptional quality.
i got mine in 2 days, but.. Charged them up last night and used them today for 3 hours none stop. they fit great, sounds great and they were perfect for what I was using them for. Thanks for the link!
