Got my ipod's rca cable today, and i wondered if i was able to hook it up to my 22" LCD, i googled for some rca to vga, apparently all i found is cable to hook rca displays to pc.
can anyone help?
thanks!
You won't be able to do it with a simple cable or adapter. You'll need a transcoder or converter of some sort. Google for products that say "pc to tv converter" or "tv to pc converter" and you'll see what i'm talking about. Ideally you'll try to find one that scales close to your monitor's native resolution.
Try not to go too cheap since product quality varies drastically, and buy from a merchant that offers easy returns (in case you're not satisfied). You try can buying a $30 ebay special but i can almost guarantee you won't be satisfied.
