Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have used the stock razer feet, the pads that come with the icemat, and normal teflon tape. All three of them made the scratchy sound you are referring to and I really didn't notice too big of a difference between them as far as noise level goes. The noise is really not that annoying once you have used the setup for a week or so, I wouldn't worry about it.
