Can't get the arrow keys to work. Can't scroll right, but I can delete right holding shift & right arrow key. Also, if you shutdown your pc, but don't turn off power supply switch, the underside lights & side stripe lights stay on. What a great design. I removed all the leds, & disconnected 4 of the wires from the 8 pin connector to turn off all the leds except the keypad backlighting. I wanted a compact, quiet, backlit keyboard & this was a $100 mistake. The Razer Lycosa I have is great, just not compact or quiet, so I figured the Marauder would be OK, but Razer stuck me with this one. Methinks POS.
