Razer Lycosa usb underpowered?
auceny
I need help from Lycosa owners. When i plug my WD portable hdd into the usb port on the Lycosa keyboard it doesn't get recognized by my computer. The light comes on but it seems less bright than normal. Anyone out there have any knowledge with this?
Why would you even want to plug a HD into your keyboard sir?
because its 10 inches closer than the usb hub on my monitor...plus its a new keyboard so i was like hey i should probably use this port at least once. at which point it didn't work properly.
Why would you want to plug a HD into your monitor sir?
LMAO ^^^^
Use either a POWERED usb hub or plug your hard drive directly into the computer. I'm assuming your external is the 2.5" laptop drive type and that your not forgetting to use the power adapter that came with the 3.5" drive types.
Still laughing--
