So I just got the Razer HP-1 Headphones and I'm quite happy with them, except for the Bass.
The Bass setting on the 'remote' does absolutely nothing.
I did hook it up to my Audigy 2 ZS correctly as the 5.1 surround is working.
Does anybody have some experience/tips on how to get more Bass through the headphones? Or how's the Bass with
other soundcards (X-Fi etc) or Razer's AC-1? Or is there some setting I'm missing?
The other problem I'm now having is that previously my Logitech Z-2300 Speakers were plugged into the soundcard using the green plug and my
old headphones were plugged into the speaker's 'remote'.
This does not work anymore as I have to plug the HP-1 directly into the soundcard. To use the speakers, I now have to change the green plugs on the back of my computer which is quite annoying.
Is the only way around this to get a soundcard with a front panel (such as X-Fi Platinum) for an additional plug for the speakers? Or is there another
solution?
Thanks for the help guys!
solution?
