Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
There is no equivalent mouse made by Microsoft. This mouse is designed ground up to use Microsoft's standard mouse structure, with a few tweaks. Along with razer's laser engine. This mouse is leaning toward the low sensitivity player, the players that use giant mouse pads. The only thing close to it would be the Razer Copperhead, although it is made for flick players. Which is why they teamed up with Microsoft, "players" wanted a low sensitivity option, with high dpi. I may get one just to test it out. I have a g5, g7, and Copperhead. Right now I prefer the g7, even though it has some problems on my Icemat.
I have been using Logitech's for awhile now (mx510, g5, and now g7) and am looking for a change (for no good reason though). I was thinking about checking out the Habu or the Copperhead. I saw on the Razer site the same thing mentioned where Habu is for low sensitivity and Copperhead is for flickers.
Couldn't you just decrease the sensitivity/dpi on the Copperhead or increas sensitivity/dpi on the Habu to make them respond the same? Or is it that they don't track properly using them for the opposite of what they were meant for. I am guessing I would be considered a flicker, but the shape of the Habu looks awesome. Any suggestions?
I have both, and I'm not convinced that the Habu is for low sensitivity playes, it feels just as fast and accurate as the copperhead, just feels much more comfortable in hand. If you a low sensitivity player you should get and optical or infrared based mouse not a laser anyway... save the cash.
The Habu and Copperhead are the same internally so I can see why it may not be the best for low sensitivity people.
Right now I would not get a Habu because the drivers, firmware, and software suck.
Out of the box you need to use the CD drivers or it won't work. Then you should flash the firmware and it will work with the latest drivers/software. The problem I have with it is the lack of sensitivity options. With my diamondback the sensitivity control was on a scale of 1-10, so it can be adjusted in small intervals. The Habu only has 4 preset DPI settings, 400, 800, 1600, 2000. Thats pretty sucky. Also the display for on screen on the fly sensitivity doesn't work for me. (v2.01 software and v2.01 firmware)
So far I prefer the G5, I like the software and build materials logitech uses much better. I don't like Razer hard plastic, though their mice are light.
