Razer Diamondback Install Issues..HELP...?
TheBlueChanell
I got my Razer Diamondback Plasma that i've been patiently waiting for, for over a month.... :( when you preorder something you should get it when it comes out,not a month later. Anewayz I am having trouble installing it. The drivers won't work. And I have to delete my other mouse drivers and I tried that. It still doesn't work.
Have you checked out Razerzone ? They have updated drivers on their web site along with installation instructions. I had problems installing the one that came on the CD, so I got a newer driver from the web site and they work okay.
Well, It say's i have uninstall all my mouse drivers before I install it. but if I do that my other mouse won't work. And using a keyboard to navigate windows is a tedious task.
Strange, your system should default back to windows drivers after you uninstall. If you have a PS2 mouse, uninstall your mouse drivers, shut down, connect PS2 mouse, then power back up and it should allow you to install Razer drivers. Make sure you have the latest drivers off their web site as they have fixed several issues with this release.
Good luck
I just picked up a razor viper for $20 today....and I had to install their latest drivers, otherwise it crashed my games. But now that is all peachy.....im simply amazed. I never really thought that there were differences in mice....but wow, what a great mouse. I gave my old crappy MS one to the cat. :)
To delet drivers you go to my pc/control panel/system/mouse/drivers then waht. I have never had a problem with drives before...? :( ahah I feel like a mega noob.
Right click My Computer> Manage> Device Manager> Mice and other Pointing Devices.> Right click on your mouse> Choose Properties> Driver> Uninstall
gl :)
Ok. :)
With 98 you can still get there this way:
1. Right-click My Computer> System Properties.
2. Next, click on the Device Manager Tab and select the mouse> Right click on your mouse> Choose Properties> then again 98 just has an Update tab.
Removing from Safe Mode:
Restart your computer, press and hold down the CTRL key after the computer completes the POST , and then choose Safe Mode from the Startup menu.> Right-click the My Computer icon on the desktop, and then click Properties> On the Device Manager tab, click the PLUS SIGN (+) next to Mouse to expand the branch.> Click any of the devices listed under Mouse, and then click Remove> and then click OK.
Do you have any current mouse software listed under add remove programs, delete if so.
i thought that in order to install the razer drivers, the mouse had to be plugged in as you were doing it. i just received my plasma LE yesterday so i i know that i got this message. the process i used was 1) uninstalled previous microsoft drivers 2)restarted computer 3) LEFT OLD MOUSE PLUGGED until i got into windows 4)THEN unplugged it (its a usb mouse). 5) plugged in the razer 6)put in install cd 7) followed instructions......i have had no problems. but like i said the install program told me that i had to have the razer plugged in in order to continue with the install.
