Skull_Angel
- May 31, 2010
Mechanical keyboards are mechanical keyboards with everybody using switches from the same small pool of vendors. I got the black widow ultimate because I use a Deathadder and wanted to deal with the same driver suite rather than multiple. No complaints about it at all.
I'd have to disagree here; there are noted quality differences between some board manufacturing plants (Cherry MX switches them selves come from one plant in Bayreuth, Germany, iirc), and while the company that Razer uses to manufacture their boards has come a way in quality gains, they still seem to have more issues with their solder joints than the other big names.
Then there are boards like the TVS Gold and cheapo Chinese boards using Kailh's Cherry MX clones (which are what Razer is planning to use). Mechanical boards inherently have a higher failure rate than standard rubber dome because of the number of connecting points and moving parts; Cherry MX switches were designed with a high build quality in mind so that they would have a low failure rate, but there are still a small few that get past QC that don't work (properly). When you drop the quality of a key component (the switches) on something that's already considered to be of borderline quality, what happens?
