Laser mice (no matter how high the dpi) are inferior to good optical mice (like the 3g infared mice by razer). So, razer deathadder is better .
What's your proof for this?
the best sensitivity and accuracy is an oldschool ball mouse
I also have a problem with Logitech's theory behind mouse feet. The G series Logitechs have a large surface area that seems to create more drag, especially the G9.
The Razers on the other hand, do not have this issue. They all glide with very little effort and it really smooths out the movements.
Currently using 1600DPI and starting to find im getting too used to it and wanting to be faster, guess that is considered high levels of sensitivity, I think?
The heated debates on mice and sensors etc always seems funny to me. Choosing a mouse is always personal preference. Go buy both then try them out. Return the one you don't like (or both and then buy the one you want online cheaper).
I did this for the copperhead, G5 and G7. I ended up keeping the G7.
As for ball mouse. Old School Boomslang 2000 FTW![]()
Precisely. It's a pointless endeavor to try to quantify the goodness of a mouse. ESReality's review does nothing but tell you numbers that don't actually mean anything as far as the practical application of the mouse goes. Either the sensor skips for you at the speeds you move the mouse at or it doesn't, you don't sit at your desk measuring the shit to compare it to the failure velocity that crackpot calculates. The shape is uncomfortable in your hand, the buttons suck, the software is bloated and broken, the feet blow ass, it doesn't work well with your particular mousepad, these things cannot be quantified or anticipated, you just have to FUCKING TRY THE MOUSE.
For mice that have problems at either low or high DPI, can't you simply set it to a safe DPI range, and then change the actual "Sensitivity" setting, either in-game or in Windows? Or will that still produce the same problems?
Anyway, I used the MX518 for a long time, and its definitely an amazing mouse. Mine eventually became very worn out though, and makes an annoying high-pitched whine that drives me insane. I bought a G9 a couple months ago, and while its a good mouse, I don't like it as much. The right click is far too sensitive- I can't rest my finger on it without clicking(and I by no means have heavy fingers). The thumb buttons are too close together as well, I often click both by accident. It is comfortable and tracks well, though.
I ordered a Deathadder over a week ago and it still hasn't arrived, so I'm starting to think it was lost in the mail(it shouldn't take 5 days to go through one state). I'll post what I think about it if it ever arrives.
The G9 just looks so....ew to me. IDK, it just isn't my style. It looks very uncomfortable,
i thought the exact same thing. i just gave it a shot and like it. funky looking mouse but its pretty sweet actually. its very high quality, i'll give it that. its like they took the MX revolution and made it a gaming mouse, i dont care for any logitech mice but this one.
You can't really do that. The mouse's performance is too contingent on too many factors. It really has to be the right mix. Some mice do interpolation at the software level to "fake" a DPI higher than the mouse is actually capable of doing. This causes skipping and all kinds of other issues that can't simply be remedied by lower Windows mouse sensitivity. FYI, if Windows mouse sensitivity is anywhere above or below the 6th notch, you won't get 1:1 cursor movement, so you don't want it anywhere other than that notch. From that point on, you can determine what setting you want to mouse to be at.
Thanks for that info, I'll be sure to keep it at the sixth notch from now on. But what about the sensitivity setting in the Logitech software? And how about in-game sensitivity settings? Are they both detrimental to accuracy as well?
