If you check out Razer's website(www.razerzone.com) it appears they are releasing a new mouse called the Copperhead. The specs look nice, 2000dpi laser and 1000hz. The look still seems to be the same however.
No, it's the third laser mouse (OptoRite ML100). They aren't liars though, it is the first gaming laser mouse.laxmiddi44 said:its the second laser mouse.....liars!!! logitech's mx1000 is the first laser mouse (and i have it hah)
It's the flash animation on the front page.MISMCSA said:I'm looking all over the site for information about copperhead. All I see is stuff on the diamond back. A little help please?
Well you can see two side buttons in the flash.Darakian said:Hmmmmm tempting, can anyone tell me if razers have extra buttons on them like the logitech 5XX series?
who cares,it sounds [H]CreamySoupUSA said:What's the onboard memory good for?
TekSomniaK said:http://hardware.gamespot.com/Story-ST-21730-2416-x-x-x
Looks like a kickass mouse, but the $80 price tag is pushing it.
Jesus_Faction said:bet it would be good for aimbots and wallhacks too
did your boomslang every break ?Jima13 said:IIRC I paid $99 for my Boomslang 2k back in late '99. Along with the BS, I've got the Viper & Diamondback, and an eXactmat. Looks like Copperhead will soon be added to the stable![]()
But if it's wireless overclocking your usb ports does nothing. I need more that 125Hz poling rate!J-M-E said:Ill stick with my MX1000. Buying a copperhead wouldnt do me any good, I already pwn with the mx1000 and dont see any need for it to be more accurate haha.
Plus I love that its wireless
The mouse doesnt make the man!!.....
Sweet! built in usb overclocking. Now I know I will get this mouse, no more useing crappy hacks!Gamespot Hardware said:The new laser system samples at 1000Hz. The polling rate results in a 1ms response time. In comparison, conventional mice poll at 125Hz for a response time of 8ms. You will be able to adjust the USB polling rate to 125Hz, 500Hz, and 1000Hz.
Shike said:...no one believes me when I talk about the MX1000 delay from not always being on until they play with it...
Master Honshu said:There are two buttons on each side. And yes, the 32mb of memory is to save your configurations so that they are with you no matter where you plug the mouse into.
HHunt said:With 32mb, you could probably store the configs of all mice in you county several times. (How much does a mouse config file take? A few hundred bytes at most?
linjy2 said:did your boomslang every break ?
could have bought new slide tapes...Jima13 said:nope, I used it till the feet wore out![]()
Thank you, that sounds better.astern said:There's 32KB of onboard memory, not 32MB.
There ain't no kill like overkillMaster Honshu said:But some say that 2000 dpi is overkill.
