Razer Copperhead Double Click edition
Koko56
I RMAd my Copperhead as it started double clicking - then after a lenthy process with Razer I got a mouse that was alight - I got 3 in total as the first two had pushed in buttons basically.
Now the one that I got from the RMA process is double-clicking as well. So I'm thinking, do I buy another one, or not.
I mean, if I get it from an good -etailer, I should not have too many problems if the double clicking issue arises again, but at the same time I don't really want it to happen in the first place really, but I guess I could wait a week or two if it happens.
I've gone through a few mice and while the Copperhead is not the "perfect" mouse for me, I like it the most out of the ones I've tried. ( it is not ideal for BF2 in case as well as desktop usage as it is a bit twitchy, though I sort of used to it while using on desktop)
(G5, MX518, Intellimouse 1.1, MX400, Deathadder, Habu... etc the more expensive ones in the shops though)
My copperhead i've had for years and have yet to have the issue you described. It literally is 6 years old plus. I now just started using a special edition one. Maybe wait a few months and order from a place that wouldn't have a bunch of stock or pick up at a local store so you can return it. Possibly walmart would have it on their online store for ease of return in person?
