RAW picture viewer for Vista?
Verse914
Just wondering if there is a RAW picture for Vista? I know there is one for XP, but I cant find one for Vista...I know I can use Adobe Bridge, but I like like RAW picture viewer better.
Any RAW viewer that worked in XP should be ok in Vista. I used Nikon's Capture software in XP and it's working fine under Vista.
Nikon has also released a codec for viewing RAW images: http://www.nikonimglib.com/nefcodec/
This will let Vista display Thumbnails of NEF/RAW images and Vista's Picture Viewer app read the files. You will still need a RAW editor to make changes to the file, but you will be able to view/print them with the codec alone.
thanks griffinhart. I have Photoshop, but its a pain to use Bridge to view thumbnails and NEFs compared to Microsofts RAW picture viewer.
