Rather odd things
http://forums.extremeoverclocking.com/showthread.php?t=290266&highlight=p5k+vdroop+mod
here's one i found at extreme overclocking forums. don't know if it applies to your mobo. scroll down to post #4.
one thing i want to warn you is to not to "draw" too many lines. do about 2-3 passes and check your idle to load voltages. if it is pretty close then you know you're on the right track. you can get it to match perfectly but you can also end up load voltages higher than idle. performing the mod can also increase both idle and load voltage, but this is normally due to drawing too many lines.
