Rate my under $700 build
Shadey216
Ok so my P4 2.6C motherboard finally died on me, so I guess it's time for an upgrade. I've been out of the loop for a while now, so I'm having a tough time picking an optimal setup. I'm pretty broke as well, so I'm trying to stay under $700.
I already have 2 hard drives, case, sound card, etc.
Here's what I have:
$181.00 - Core 2 Duo E6300 (Plan to OC it)
http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
$135.00 - GIGABYTE GA-965P-DS3 motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813128012&CMP=BAC-HardOCPGuide0406&ATT=Gigabyte
$153.00 - CORSAIR XMS2 1GB (2 x 512MB) DDR2 800 PC6400 Model TWIN2X1024-6400C4 (I will upgrade to 2GB later)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145040
$180.00 - eVGA 256-P2-N624-AR GeForce 7900GS (Will upgrade later for DX10)
http://www.newegg.com/Product/Product.asp?Item=N82E16814130056
$40.00 - Thermaltake TR2 W0070RUC ATX 430W Power Supply (Amazing rating on Newegg, still kind of worried)
http://www.newegg.com/Product/Product.asp?Item=N82E16817153023
Total: $689.00
I may try and get a Scythe or Zalman HSF to help with my overclock.
Let me know what you guys think!
Looks great to me, I would be worried about power as well if I were upgrading to a DX10 card in the next few months but until then I think that will work OK.
Another nod for the XClio - I have the 480BL and it's been rock solid for nearly a year now. That said, you want want to budget a bit more into the PSU, given there will likely be little in the way of expansion capability later on, even w/ the XClio. I would take whatever you may budget for 3rd party cooling and put it towards a better PSU now, and get the better cooling once you're ready to upgrade for graphics setup.
[edit] Not all TT PSU's, but I wouldn't recommend that one for anything but the lowest of systems (read: old tech, no DC/DX10/etc what-so-ever). 1x18a 12v rail is not going to power jack in a current mid to high-end system.
r3awak3n said:
are thermaltake power supplies really that bad?
All of them except the Toughpower line are pure crap. Even the Toughpower line has it's issues, but it's a BIG, no, GIGANTIC step forward for Thermaltake.
I agree on the power supply change. I would make another change though. Save up an extra $60 or so and just get 2 gigs of RAM now. Prices aren't going to go down for a while, in fact they've been going up recently.
Actually as of the last couple weeks they've been coming down bit by bit. It was predicted a few months agot that December would see the RAM prices come back down, and well it seems to be happening. How far it come down is another story though.
