Rate my System
tblespaul
Case- Antec Solution SLK3000
Power Supply- Antec SmartPower 2.0 SP-450 ATX12V 450W
CPU- Athlon 64 3000+
Motherboard- ECS NFORCE4-A939 (1.0) Socket 939 NVIDIA nForce4
RAM- Samsung 256MB(x2)
CD Drive- NEC DVD+RW
Hard Drive- HITACHI Deskstar T7K250 160GB 7200 RPM IDE Ultra ATA133
Video Card- MSI Radeon X800 256 MB PCI Express 16x
Monitor- DELL UltraSharp 1905FP 19-inch Flat Panel Monitor
Speakers- Accent 2.1 set
PLEASE GIVE HONEST OPINION :D
5.12 intel 486s outta 10
Total of 1 gb of ram and a faster CPU would get you a much better score :D
Changing the motherboard would be a good change also. (had a very bad
experience with ECS boards back in the day)
I would up the ram. 512 is like the BARE minimum. I'm not sure what you are planning to do with the rig, but at the very least get 1x 512 stick instead of 2x 256.
If you plan on gaming then I would highly suggest 1x 1gb or 2x 512.
3, if you rate it out of the best stuff on the market. what is this machine gonna be used for.
def more ram, but try and run dual channel even if only 512. that is, no matter how much ram you use run it in dual channel for sure. you can always sell and get two new modules. 512 is not too bad for casual use, but no one here is a casual user :p
450w should be fine, but add the amps up and double check
Judging that you have a nice video card in there, I am asuming that you will be doing gaming. Up your processor to Athlon 64 3400+, one stick of corsair xms 512mb pc3200 RAM instead of what you have now, you PSU is fine. Once you get the money upgrade to another stick of 512mb corsair xms RAM. In duel channel and you will be fine. I suggest if doing heavy gaming right now then you go for 2x 512mb corsair xms RAM, but it is your choice. Everything else looks great, especialy the monitor.
