joecuddles
- Aug 16, 2004
2x MCP600 pumps : $158 USD / $193 CDN
http://www.cooltechnica.com/Merchan...ROD&Product_Code=AQX-50Z-DC12&Category_Code=P
1x Dual 120mm Heatercore (with 2 2x120mm shrouds) : $82 USD / $100 CDN
http://www.voyeurmods.com/index.php?action=item&id=658&prevaction=category&previd=23&prevstart=0
Silverprop HL Fusion (GPU) : $58.50 USD / $72 CDN
http://www.silverprop.com/cyclonefusionhl.aspx
TDX (CPU) (#5 nozzle)
-> (silver) : $125 USD / $153 CDN
-> (copper) : $53 USD / $65 CDN
http://www.dangerden.com/mall2/more_block3.asp?fmmore=213
AquaComputer Aquatube Reservoir (with 1/2" mod, LED Lights, Aluminum mounting bracket) : ~$117 USD / $143 CDN
http://snt-systems.com/catalog/product_info.php?cPath=26&products_id=38
~Total for Watercooling with Silver TDX : $541 USD / $661 CDN
~Total for Watercooling with Copper TDX : $469 USD / $573 CDN
Tygon tubing, lighting comes later. Obviously I'll be using clamps and such, those are small expenses. Using Sanyo Denkis for the fans, provided I can find them, all controlled by a 3.5" fan controller. 4x120mm (heatercore) and 4x80mm (case) fans. Specs in sig, GPU / CPU only.
Any final suggestions?
