Hi, this is my second attempt of overclocking, the first one was only overclocling de cpu, now i started with the GPU, i would like to remind you that, 3 weeks ago, i didnt even know what a FSB was, so thats why i bought a Mobo without agp/pci lock
My specs:
- AMD Athlon64 3000+ 512k L2, (stock 2.0hz, OC : 2282mhz @ 228x10) 37celcius idle, 42 celcius full load, stock heatsink cooling
- MSI NeoFSR k8t800 (no agp/pci lock options *shit why im a noob
- 2x512 Corsair Value Select RAM DDR400 pc3200 CL2.5
- Ati radeon 9800XT stock speed of 412/ 365, OC 444/402 @ 63celcius idle, 69celcius full load
System temps: Idle 32c, Load 38c
Here some benchmarks:
3DMARK01: Stock=18,838 | OC=21,138
3DMARK03: Stock=6,573 | OC=7,218
AQUAMARK03: Stock GFX= 6,207 Stock CPU= 8,248 | OC GFX= 6,798 OC CPU= 9.390
My questions:
-Can i override the fan speed in ATI tools more then 100% ?
-Should i lower the memory core and higher the core speed of my GPU ?
-Are my temps too high (there is a controvercy when i ask for my GPU temps, some are telling me that its WAY too high, some are telling me that below 75c its correct
- Should i try OC my RAM too or my case temps are too high.
Thanks guys!
My specs:
My questions:
Thanks guys!
