mastrmndv2
- Apr 11, 2006
Just as simple as it sounds. I recently decided to do the water cooling venture after college dorm room temps. kept me from a) having any type of a decent ambient temperature and b) much more room noise with all the fans in a smaller environment. Due to these reasons I chose watercooling and decided to do things a bit different.
Upgrades:
SiverStone Tj07 Case
2x Black Ice Pro Rads
DD Low Profile Blocks for Gpu's
DD Res
Thermaltake CPU Block (I chose this for a variety of reasons and tbh I'm quite happy with the results even though I know there are alot of TT bashers out there.)
Other Misc Equipment (tubing, fittings)
Hardware:
Asus A8n SLI Deluxe
AMD 64 3000 Venice Core
Corsair CMX512-3200C2 3-3-3-6 DDR 400
2x MSI 6600gt's SLI
Results:
The results I obtained from overclocking after watercooling were quite high to say the least compared to what I was getting on air.
Cpu = 2.7 ghz at 1.5v on 10x multiplier at 30 idle
Gpu's = 601 core and 1202 on the mem. Idle 34 degrees
HT = running at 1350 mhz at 5x mutiplier
RAM = 448mhz at 2-3-3-6 timings at 1t
Load temps settle in between 38 and 40 degrees all across the board. Water tubing size is 3/8 and 1/2.
For a quick comparison with this same hardware I used to net a score of 2205 (nonoc'd) in 3dmark06. Overclocked on air I could get 2841 in 3dmark06. Overclocked on water I now get 3183 in 3dmark06.
For another quick comparison in 3dmark05 I used to net a score of 5498 (nonoc'd) in 3dmark05. Overclocked on air I could get 7060 on 3dmark05. Overclocked on water I now achieve a score of 7825 in 3dmark05.
*Keep in mind no hardware was changed other than a new case and watercooling parts replacing air cooling.
What do you guys think?
Upgrades:
DD Res
Hardware:
Asus A8n SLI Deluxe
2x MSI 6600gt's SLI
Results:
