Rate my Oc (first OC ever!)
Shogo
My specs:
Athlon 64 3000 2ghz @ 2301.4mhz (10x230mhz)
Msi Neo FSR K8T800 Vcore 5.55(maximum) default 5.50
Ati Radeon 9800XT 412/365 @ 432/378 =66celcius
temps from mbm5
cpu heatsink fan = 3375RMP (is that too low?)
cpu temp 39celcius idle, 43celcius fully loaded
sys temp 38celcius idle ,39celclius loaded
Gpu temp 65celcius idle, 69celcius loaded (i heard it was not accurate temps so i should not panic, temps are from ATI TOOL)
Stock 3dmark01SE = 18812
O'cing 3dmark01Se = 20613, now 20995!!!!
O'cing 3dmark03 = 6720
Stock heatsink, + 3x80mm fans that comes with my case
Is it too hot ? should i be able to go higher with stock fan like that?
Dis ain't bad considring your motherboard doesn't have AGP/PCI lock. I could onlt get 2.15Ghz on my MSI NEO. Your saying Vcore is at 5.5v. That doesn't sound right. My Vcore is only 1.7v Make sure your reporting the right thing.
Your motherboard must bre friggn' awesome to run at that speed with no AGP lock. You might be able to hit 2.5+Ghz with a mo that had AGP lock.
Have you tested for stability using Prime95? If not then you need to do that.
yes 1.55v hehe not 5.55 sorry :p
this is the higher i can go....
MemoryInAGarden said:
You're above 3400+ speeds. Not bad at all for a first time :)
hehe thx dude.... im just hoping it wont be the last time i overclock..... its all new for me, yesterday i didnt even know what a multiplier was..... and what a Vcore was...
now i have regrets for not buying an AGP/PCI lock Mobo, and a good heatsink....
ill just sell my radeon 9800XT and get a x800..... one day ehhe
