Rate my new build.
kurtparn
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX All Solid Capacitor Intel Motherboard
Intel Q6600
G.SKILL 4GB (2 x 2GB) DDR2 SDRAM DDR2 1066 (PC2 8500) F2-8500CL5D-4GBPK
2x Scythe S-FLEX SFF21D 120mm Case Fan
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Visiontek HD 3870 OC Edition
500 Gig Seagate Barracuda SATA
Antec 300
I ordered this, should be receiving it on Tuesday. Cost me around $750.
Looks like good deal! You might me a little tight on power however so you might need to keep an eye on that. You'll definitely need a new PSU if you go for a higher end GPU.
I am using the hard drive which I have in my current PC. Everything besides the Q6600, HD3870, and case I got from Newegg. The motherboard is open box, as I don't need any SATA cables or accessories. I missed out on a sale for the video card from Best Buy, they had it for 215 i paid 250. I should have just ordered that from newegg as well, as they have cards for 170. I bought the video card from Best Buy, before going to Microcenter, where a check did not go through; so I ordered everything from newegg besides the CPU and case, in which I returned to Microcenter to buy them with cash. I gotta say I am using the HD 3870 in my AMD build right now, and it is great.
Price list and links:
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059R $69.99
CPU: http://www.microcenter.com/single_product_results.phtml?product_id=0283289 $199.99
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166 $138.99
Case:http://www.microcenter.com/single_product_results.phtml?product_id=0283272 $49.99
Video Card: http://www.bestbuy.com/site/olspage.jsp?skuId=8762234&st=Visiontek&type=product&id=1203815034383 $249.99
DVD Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827106070 $25.99
Heat Sink: http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003 $36.99
Power Supply: http://www.newegg.com/Product/Product.aspx?Item=N82E16817159054 $54.99
The motherboard I guess went up in price or there was a deal. I lied if you add the price up minus the fans it comes to around $827.00.
