rate my close to completely decided WC setup
Luca25
i just got a $75 gift certificate to frozencpu, and i thought what better way to spend it than to watercool my shuttle
so, i decided upon this:
i would buy the rad and CPU block from frozencpu,
and the pump, res, and tubing from dangerden
and this is all on a tight budget, mind you
From FrozenCPU
Swiftech MCW6000-64 waterblock @$42.50
DD BIpro 120mm radiator with a vantec stealth @ somewhere near $55
Total: $97.50
less 75
22.50 at FCPU
From DangerDen
DDC-12V Pump @ 74.99 (have you seen the size of this thing?)
Clear cylindrical Reservoir @ 27.99
6 Feet of tygon @ $2.35 a foot, $14.10
Little bottle of ZEREX @ $4.50
total = 121. 58
so total total is 145.08 plus shipping, etc.
is this a good deal,
any sugestions?
Doesnt Frozen have a super sale going on Swiftech kits? Up to 40% off? Or is that over? Might be the best way to go. The DD v12 pump and the Swiftech 650 are the same Liang D4 pump with different badging.
Checked their site, sale is still on. Def take a close look at it.
see but ive got an athlon 64
and the only athlon 64 kit has on 80mm rad, which begets small, loud, 80mm fans...
any suggestions?
but as i stated before, this is a shuttle, and 2 120's would be a tight squeeze in my tower case, let alone a shuttle
so unless theyve got some in stock that arent listed, itll wither be the above setup or a Tt bigwater
if i wanted dual 120s, i'd get a 77 bonneville heatercore
Oops...didnt notice it needed to be a single 120.
Id take ur initial setup plan over a thermaltake bigwater any day. I cant see anything wrong with it.
