Rate my cables!
Giturar
Alright, I just spent the last hour or so cleaning up my case.
Before, cover on:
http://www.acelius.com/images/before_coveron.jpg
Before, cover off (look at that mess!):
http://www.acelius.com/images/before_coveroff.jpg
After, cover off (what an improvement!):
http://www.acelius.com/images/after_coveroff.jpg
After, cover on (I love the UV reactive round IDE cables)
http://www.acelius.com/images/after_coveron.jpg
I think I did alright, this is the first time I've ever attempted any sort of cable management, I left the IDE cables out, becuase 1) theyre uv reactive, and 2) theyre uv reactive, so whereever i hide them, they glow :)
:D
The bottom is still a little messy but other than that its pretty good. With the cover off I mean.
that 4th pic woulda been better without the flash :)
Good work cleaning your room.. err case.
with panel on: 8.5
with panel off: 7
you could try to have your IDE's bend the same way or somthing more attractive. and when ur panel is off, the HDD cables are a tad messy
Looks good. I think that you could still do a little works on the cables on the bottom.
thanks for the replies
first, i have two fans on the bottom of the panel, thats where those cables are coming from, i wasnt too sure where to put them, but since the bottom of the panel covers it up, i didnt worry about it
ill try playing around with the IDE cables some more problem is, the video card is in the way, i dont want them resting against the side of the panel
thanks again :)
im actually looking at new cases, this one doesnt have a lot of room to work around with (plus i botched up the blowhole ;) )
i can see where your going with the bottom because the side pannel covers that up. it looks much better. how better are your temps? 4 degress cooler im guessing
actually i didnt see THAT much of a difference
before, i was getting about 27 idle, 29 load
now i get 26 idle, 27 load
ambient room temp is about 25
so eh, it looks a whole lot better though :)
my temps where at 32 before my wire job now my temps are 26
