rate my build
eeyrjmr
[H]ardness Supreme
Going to re-build PC in 2months and am pricing atm
initial spec put the new PC at this
Intel Core 2 DUO E6700 "LGA775 Conroe" 2.67GHz (1066FSB) - Retail
Asus P5B Deluxe (Socket 775) PCI-Express DDR2 Motherboard
HD-093-SE Seagate Barracuda 7200.9 160GB ST3160811AS SATA-II 8MB Cache
Samsung SH-W163 16x16 DVD±RW Serial ATA Dual Layer ReWriter (Black)
Antec NeoHE 430W Modular ATX2.0 PSU
Swiftech H20-120 Premium Watercooling Kit (Socket 462/478/LGA775/754/939/940)
Arctic Ceramique Thermal Compound (2.7g)
Gainward BLISS GeForce 7900 GS SILENT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB)
anything glaringly wrong with this setup?
dont need wifi card,snd,mouse,keyboard,monitor (salvage from present)
add a circuit-writer pen to the list for voltmodding that 7900GT!
Otherwise, looks like a great system. There are better PSUs available though, and also you'll want to look for quick HDs with 16mb caches.
tnx
I am concidering dropping the CPU from a 2.67GHz to a 2.40GHz to free up some cash to upp PSU as well as changing the GS card for a GT card (with a GPU-RAM drop from 512 to 256)
tnx
eeyrjmr said:
tnx
tnx
You really need to upgrade your PSU, yeah, especially if you upgrade the card. I'd recommend this , which is more than you need to power that system but leaves you room for expandability and overclocking (which I assume you will do with such a high-end setup).
Yeah...thats far more than overkill. He can save money from both of the PSUs he was looking at and go for this higher quality FSP. This XClio is also a good alternative. That OCZ would only make sense if he's going SLI.
1.) Agreed, get a better PSU. FSP is a great brand.
2.) Don't get 4gb of RAM unless you plan on using not-windows, or Windows XP x64. If you go with x64, you may need to put a bit of effort into it. It works flawlessly for some people, it's been a bit frustrating for me, but it's nice to be able use all 4gb of your RAM.
3.) I also agree on a different HD, try the Seagate 7200.10 @ 320gb. They're ~$100 currently. I have one and it is very fast.
Newsboys2004 said:
Vista is only in a couple months. I'd get the 4 gigs and wait for vista.
4 gigs of RAM huh? Unless this guy is doing a SERIOUS amount of workstation/serving with this system (doesn't sound like it to me), he'll never use it all. There are much better ways to spend $200, so I say save it and stick with 2 gigs of RAM.
