rate my build plz
k0n
hello all,
like many of you, i cant wait for the amd price drops. i havnt built a system in a quite a while, and its time for a major upgrade.id appreciate it if you could all critique my build. constructive criticism and questions on my selection is welcome. thnks!
Lian-Li PC-7BW Plus
Asus M2N32-SLI Deluxe
AMD X2 5000+ Socket AM2
Zalman CNPS9500AM2
Corsair XMS2 2GB
Western Digital Raptor WD1500ADFDRTL 150GB
PC Power & Cooling 510 SLI-PFC ATX12V 510W
Creative Sound Blaster X-Fi Fatal1ty FPS 7.1
NEC 16X DVD±R DVD Burner ND-3550A
*already got a vid card :)
Wow. Looks like a good build.
I think the 5000+ is a bit overkill as you can buy something cheaper and o/c it. My .02 though...
yeah I think the 3800+X2 (if thats the right one) is much cheaper being the lower tier X2 but has lots of OCing potential, however if you dont want to OC just get the 5000+ you already picked...as it will be much cheaper tommorow with the price cuts! But than again...so will the 3800.
its a very nice amd build:)
What kind of GPU you already have? ;)
9/10
Get a storage/backup drive, 320gb WD for $110 shipped
Whats your video card
IMO, the fatality is overkill. Ask yourself, do you really need a red light, a chip of ram on a SOUNDCARD, and 5.25" front bay? Save a few hundred and buy the HD.
Drop the Fatal1ty crap and just get a high end X-Fi. It is way overpriced, as dchrsf said.
I would expect you to get 7900GT/GTX SLI with a system of this high of standards. But a system is not all about putting together high-end parts. I want to see some modding or overclocking, then you will deserve a 10.
9/10.
thanks for the constructive reponses!
the reason i went fatality (hesitant at that) was because of the onboard 64mb x-ram, which i read takes the load off the cpu a bit.
what would you offer for a suggested replacement? i kinda think its over kill as well too *shrugs*
also is my ram selection the best possible and compatible choice?
im open to suggestions!
http://techreport.com/reviews/2006q1/xfi-fatal1ty/index.x?pg=14 :)
Xtreme Music, or Platnium if you need the front bay.
About RAM, not sure but corsair is a solid company so I'd doubt thats a bad product if that is what everyone else is purchasing for their AM2 systems.
For $200, it's hard to beat RAM that does 420MHz+ like it's nothing at all.
