Rat 7 vs G500?
Zake202
For general gaming what do you think is better and why?
I already own the G500 and like it, but the Rat 7 caught my eye today at work.
I read about it for maybe 5 minutes and saw some negative reviews regarding the laser acting up.
Anyone comment about either or own both?
I have the Rat 7 and haven't had any problems with the sensor although it's best to use it on a flat surface/mouse mat. It's an unusual design that you may or may not like (it's taken me about 2 weeks to get used to it but now I think it's great) so you may prefer the more "standard" ergonomics of another mouse. The Rat7 is also quite expensive which might be why there are a few complaints about the mediocre software, button placement, etc. It's physically working fine though. There's a long article on the Rat series in this forum.
I don't know anyone that uses their mouse on a surface that isn't flat. :confused:
With mice that use the Philips Twin-Eye sensor, you want a hard pad. Because the Twin-Eye is capable of tracking the Z-axis you want to ensure that the distance between the surface and the sensor stays the same, with cloth pads it can make the mouse a little annoying to use when clicking.
R7 just looks too complicated. I own 2 G500's and use them day to day as well as for games... Love them. I would stick with it.
Oh, and if you do decide to switch, I might take your G500 off of your hands :p
Got my g500 two weeks ago with a g13. Absolutely love it. Best mouse I've owned.
I'm not a fan of Logitech's mice, they are built well but I don't think they are suited for more intense gaming... However I would definitely pick it over the R.A.T. like someone said, the RAT looks to complicated, and I know the g500 does fit reasonably well in my hand (palm grip). I don't actually have any experience with the RAT but from the looks of it, it wouldn't fit your hand well (even with the adjustments) and then you have the twin eye sensor, I assume it's really heavy with a metal chassis, and a few other issues I've heard about.
I used to have my mouse mat draped over a hinge on my desk which caused a slight "bump" in the mat. Moving it back over a flat (although tilted) part of the desk seems to have gotten rid of the click/drift issue for me.
It's worth noting that I've had this with just about every mouse I have used, laser, optical or ball. Also when lifting/returning to the mouse mat - they were all pretty bad for movement, at least the Rat cursor moves in a predictable way. Either way none of these issues have bothered me in game with any of the mice. It's fast and accurate, doesn't freeze ever and feels good to use. I am really enjoying it (If anyone has loose parts or another FAULT, maybe send it back for a replacement).
The biggest issues I have is the software with some things just not making sense and other features I would have preffered to see included (such as automatic profile switching). I am hoping they will add functionality in the near future. But no conflicts, driver install problems or anything that stops it working.
