HardOCP News
[H] News
- Dec 31, 1969
Those of you that own a Raspberry Pi can now overclock your unit for a 50% performance gain. The best part, it doesn't void your warranty.
You can now choose from one of five overclock presets in raspi-config, the highest of which runs the ARM at 1GHz. The level of stable overclock you can achieve will depend on your specific Pi and on the quality of your power supply; we suggest that Quake 3 is a good stress test for checking if a particular level is completely stable.
