Raptors in Raid 0 benchmarks.
Copyright
It scored 58,046 on sisoft sandra max. Is this about right? These are 2-36 gig 10k rpm Raptors.
67 megs a sec? its good but i got the same hard drives raid 0 and get 93 megs a sec on a VIA serial ata controller
I believe its just a score... your not going to get this kind of benchmark unless your using raid... my single raptor was 36,000 on a sata controller.
What driver do you guys install? I mean is it the F6 driver during the format or is there a windows driver you install in the actual OS.
T[H]anks.
The F6 driver is the same one the OS uses when it installs. I just did a windows update and it found a newer SATA driver then I had... after it installed I redid the benchmark and it showed a good differencde in the benchmark.
