computersoc
- May 28, 2006
Here's my story...
NEW:
OLD:
I had an MSI K8N Neo2 Platinum board with two Raptors on RAID 0. Look at the picture for the benchmarks entitled "OLD".
That motherboard died and killed my sound card. Not sure if the power supply was dead too, but it probably was. Everything else in the computer was fine.
Now I bought a MSI K8N Neo4 Platinum. It recognized my array! I did a repair installation of Windows and got back into Windows. I backed up all my files and then reformatted.
I deleted the partition and reformatted using NTFS (I did NOT use NTFS Quick).
I have Windows XP SP2 running now. As you can see in the benchmark entitled "NEW" the read speed is a whole hell of a lot slower than before.
The write speed is the same, but read speed is about half as slow. There's barely anything on my hard drive now.
I have the latest BIOS and 6.70 drivers for the nforce.
It doesn't make a difference with NCQ enabled or disabled.
Now, I needed to reformat anyway, so I figured I'd try something.
1. I backed everything up.
2. I disabled the NVRAID and enabled the RAID array again (re-created it). I installed Windows and there was NO CHANGE.
3. I disabled the raid array and installed Windows on a single Raptor. I got about 80read/80 write I think.
4. I disabled NVRAID and enabled the Si3114 RAID and get what is in the picture here:
I used the Si3114 and get faster speeds. Is the Silicon Image RAID crap? Should I stick with this?
Why is the NVRAID so much slower now in nforce 4 versus nforce 3?
Thanks.
NEW:
OLD:
Thanks.
