Raptor sudden drop in transfer rate, help
condition0
after a fresh vista install I noticed the suddent drop in transfer rate when testing with HDtune. This didnt occur a few days ago when I tested it when I install another hard drive. The only changes to my system is a fresh installed os, and I took the raptor out of the hdd cage, tried to silence it by leacing it on a foam. Anyone knows whats heppeing to my raptor? I dont notice any difference when gaming, should I be worried about it? thanks in advance for any help :)
welcome to the world of raptors, they dont sustain file transfer speeds well for ling file transfers, there good point is seek times, not long access time.
i know what your saying but it shouldnt be as low as 3.5mb/sec? heres another screenshot a few days ago
Run the test several times, and carefully note where the drops are occurring. If the happen in the same spot, it may be the drive acting up. If they occur in different spots, then it is prolly some kind of malware accessing the drive.
If that is the case, open up task manager, go to the processes tab, click on the CPU column till it lists the busiest processes at the top, and see if a process is jumping to the top in time with your disk accesses.
Don
If I purchase a raptor as my OS drive, how much of a speed increase would I notice from a 7200rpm hard drive?
i just upgraded(down?) from a 36gig raptor to a 400gig 7200.10. big difference in all around sluggishness. hdtune says the 400gig has an access time of 13.3ms, while the raptor was 7.7ms. I'm disappointed and might have to reinstall with the raptor as OS instead of selling it.
thanks for the reply, I have run a few tests with the task manager, theres no processes taking up the resources while the hdtune is running. I have also noticed the transfer rate drop happens at each 20%, like theres a drop at 30% 50% 70% 90% or 20% 40% 60% etc, any ideas whats happening?
Don
