Raptor - Serial ATA150?
Jadestar
I was looking into getting a Raptor HDD.
1) The price difference is pretty substantial. Is it really worth it?
2) It says the interface is Serial ATA150. This is just SATA, right? It'll work on a regular 3gb/s SATA port?
Thanks. :D
Thanks. :D
Yes it will work on ports that support SATA II/300/3G or whatever the hell you want to call it.
The new Raptors are indeed faster. The only reason to get an older 74GB or 36GB Raptor is if the price is damned good. Typically the old Raptor still commands a fairly high price premium. Basically for $100 more you can double the capacity and double the bus speed. Not that the new one is actually twice as fast or anything but you get the point.
Are Raptors worth it in general? Well I think so, but only to those who can afford the price premium for the drives. The fact of the matter is you can get 80% or more of the performance with a standard SATA II drive that will be much cheaper and larger.
For 2), yes, it will work on an SATA II port - but only at SATA I speed.
And I will have to agree with a response that the Raptor is only worth it if you want quick access speeds over capacity. And the older-design Raptors are not worth their current going price. And some of the smaller-capacity Raptors are switching to the newer design used in the 150GB model.
Yeah I thought about grabbing some of the new 74GB drives. I have never needed more than 150GB on my existing setup for my OS or programs. All my real data gets stored on my RAID-1 setup. Since I do have a decent SCSI controller I will probably get a couple 74GB 15,000rpm Fujitsu MAX drives instead.
Megalomaniac said:
RTL means retail
ah, gotcha. i missed the first AD and thought this was a new release. man is my brain not working today....must be friday :p
dont get this forum started on raid 0......
that issue has been killed.
if your going for pure speed.. then i have heard ( i do claim it to be so, nor do i endorse this) that 2 7200.10 320 or 2 74adfds can save you a few seconds on map loading...
Rob Black said:
so what will be faster, 1 raptop150 or 2 74gb in raid 0?
Are you comparing the older model 74GB or the newer one? The older ones would be beaten by the newer 150GB model and the newer 74GB drives would be faster in a RAID-0 configuration. At least on paper.
The new WD740ADFD's beat the 150's. This has been proven in various benchmarks. RAID0? No contest.
on paper, various benchmarks, yes. real life, who knows for sure.
drizzt81 said:
many times over.
agreed, i've seen this flamed WAY too much in the last month alone
