Raptor!? Question
derrico
I think im going to get a 10,000rpm raptor. Quick question, say I wanted to see the improvement with speeds for games like vanguard:soh, would I install or put vanguard in the raptor HD to see the speed increase, I think my HD is really holding me back. I play it at max graphics but Whenever I load a new zone sometimes it will lag etc but while doing this the harddrive goes nuts with the little clicks which makes me believe its my HD, my other PC parts are very good.
My system:
8800gts 640mb
E6300 OCd to 2.8ghz
Gigabyte 965p-ds3
2gigs of ram
Seagate 320g 7200rpm
+ random other things
Hard Drive im looking at : http://www.newegg.com/Product/Product.aspx?Item=N82E16822136011
Yeah, you'd need to install the game files on the WDR in order to see any benefit in load times from it.
Check if you have any control over the size of the memory buffer it uses to preload stuff.
