Raptor or two RE3's in RAID1?
knightsilver
Will be for gaming and rendering?
Two WD RE3 1TB SATA2
Would RAID1 be fast enough for games?
Really need the RAID1 for rendering.
thanks,
shane c.
Why do you need RAID1 for rendering? It's not backup.
The ideal solution is RAID0 system drives and a backup system.
Get 4 and do a RAID10 if you need redundancy...although you should just do RAID0 and have a backup system.
thanks,
shane c.
Well, that is both ends of the spectrum.
Drive speed does not really affect the FPS speed for your games. A faster drive may decrease the amount of time it takes to load the game or move between levels though.
If you have a fast enough CPU, the hard drive can limit the amount of data that you can render, particularly if you only have one hard drive and have to read and save your data to the same drive.
Now, your question is asking about a small fast OS kind of drive (Raptors,) compared to 2 very large but slower drives configured in a way that will not increase speed or storage space. Only data reliability.
If money is no object, then here is what I suggest that you do. Get a Raptor for your OS and games and to take care of the day to day operation of your system. Get 1 X 500 - 1 TB drive to store your render input data. and a second 1 TB drive to store your render output data. Also, you will need at least 1 external drive to back up and transport your output data. I suggest getting 2 external drives and rotating them when you do backups.
Don
