the driver detected an error on Device\Harddisk0\D
I am using a 73gb. WDRaptor on an AMD3200+. It is running onboard sata on a msi neo platinum. I have been getting this error repeatedly since building this system. I have reformatted many times, chkdsk comes up with NO errors on the drive. All of my nforce3 drivers are up to date. The problem is my computer will restart at random times after I see the infamous Blue Screen telling me that there is a critical error. It is the only harddisk is the computer the only other drive is a lite-on dvdrw. I have tried and tried to read about this error in many places and I can't come up with anything. This is the first computer I have built since 2001. All of this new technology is new to me. I'll put my specs down if it will help, and I appreciate any help you can give me resolving this problem.
Also if anyone could answer this for me...is there a difference in using the standard 4 pin power connect on SATA drives and using the SATA power adapter? I have a Secure connect sata cord from WD but apparently I dont have a Hot spot on my ports...so does it matter which one I use?
Thanks.
AMD 3200+
Msi K8Nneo platinum
73GB. WD raptor
Lite-on DVDRW
1GB Corsair XMS memory
BFG 6800oc
Shite PSU 430 watts (Could this be the problem? I have a 520w. OCZ on the way)
Windows XP pro w/ sp2
All drivers have been updated.
Thanks.
AMD 3200+
Msi K8Nneo platinum
73GB. WD raptor
Lite-on DVDRW
BFG 6800oc
