Raptor Deaths
Sovereign
I have recieved my new Raptor 150GB from NewEgg! However, I have to wonder. I quick formatted the drive, and installed Windows XP. After install, I was not able to boot Windows. The screen came up "We are sorry for the inconvienence, but Windows did not start successfully blah blah blah" I tried "Normal" and "Last Known Good" but neither worked. I now Full Formatted the drive (well I'm full formatting as I type). It has taken over an hour and a half to get to 90%....is this normal? This is a Raptor 150.... My old Raptor took forever to quick and full format, this full format has me concerned....HELP PLEASE.
Is it still stuck at 100%?
Is this the only system change?
Needs more info ;)
It full formatted after about two hours. Still stuck in the Loop of Doom. Put my old RAID0 250s back into action to CHKDSK the thing....
I had a similiar problem with a Maxtor awhile ago, it was dead. I'd recommend you send it back.
That would be two dead drives......grrrr CHKDSKing now. Know something went wrong, the new Windows "install" used 1.1GB of the HDD....
Do you have another computer or PCI IDE/SATA card to test the drives with? It's possible there's some problem with your IDE chipset. If you've had two drives already seemingly fail it would be worth looking into, it's possible there's nothing wrong with the drives at all. :)
If you are oc'd, turn back to normal speeds and try again. Some sata clock locks are less than perfect.
The speed of my raptor decreased substantially during benchmarks when I had my system overclocked. Lowered the settings a little bit and the problem went away.
