Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Edit: Oh. By looking at the German it seems to be that the reason I get "No SATA disks found!" is because I'm using the nVidia drivers. I should use the Windows drivers? How does one do that?
Well, I am on a Gigabyte P965-DQ6 with Intel chipset and Intel drivers and there it works, the reason why SATA doesn't work is that the IDE drivers do not support those AAC commands. Looks like the Intel SATA drivers do.
Go to device manager, to your IDE controller. Select "Update the driver", then later "I will choose the driver..." and then you should be given the "Standard IDE" drivers. Maybe it works with them.
