Random shutdowns
vanilla_guerilla
A couple of days ago my pc started powering off at random times. there is nothing in the event log. i can be idling, or playing a game. this is NOT a heat issue. i am running @ default, with an xp90 and hi output fan. my pwmic and chipset temps are both around 40C. my cpu never goes over 38C. i have felt these components with my fingers, and they are barely warm to the touch. this is also not a stability issue, as i have swapped out the ram, and used only 1 piece of ram. also, as i have said, there is nothing in the event log, and pc does not reboot, just shuts down. i have also used a 3800 x2 and an opteron 146. my motherboard is fairly new and hasnt been abused. at least not too much. i have also tried running with just my os drives, 1 video card, 1 piece of ram and no usb stuff or pci cards. it seemed to be ok for a day, but just shut down again. i am using the 704 big toe bios, and xp mce 2005. any help appreciated, thanx.
edit i have also run a virus scan, so it is not the worm that causes pc shutdowns, either.
I am a computer consultant and deal with stuff like this all the time. My first thought when I hear about random shutdowns is the power supply. After that, usually the motherboard. If possible, try a different power supply.
Hope that helps
Good Luck,
it was psu. on the 4 pin 12v (cpu) connector, the plastic around the bottom 2 pins had literally melted off, so when i swapped out the psu, the new psu didnt make good contact either. i scraped out the melted crap in the four pin socket with a dentists scraping tool (the hooked pointy thing they stick in your cavities to make you jump) and put a new connector on the psu. luckily i have a lot of connectors and psu mod stuff and psu mod tools laying around here from when i used to do that stuff a few years ago. also fired off an email to sunbeamtech about their faulty connector and asked them to send me a new cable (modular psu).
i figured it was the mainboard, a popped cap maybe but i didnt want to rma it until i was sure so i took a good look at it with a flashlight and magnifiying glass.
