Random Shut Downs - Long post - Need 2nd Opinion
Ingonuts13
So my pc has been experiencing random shut downs that are getting more and more frequent. I think it is the motherboard or CPU, but I would like a second opinion.
Here is what I have done so far:
-I have checked to see if it is a cooling issue, and it is not. (Using Watercooling on almost all components and nothing gets over 40c).
-Thought it was the PSU, but I doubt that as well. The shut downs happen totally randomly even when the PC is just sitting idle. Plus my power supply is PC Power and Cooling 850W model which should be just fine for what I am doing.
-Tested each Ram stick individually using Windows memtest and memtest86 without issues in slot A. With both sticks in the system, memtest throws a lot of errors even at stock speeds.
Specs:
DFI NF4 SLI DR Expert
Opteron 175
Mushkin Redline PC4000 2GB
BFG 7800GTX 512 SLI
X-FI Fatality
Raptors
850W Pc Power and Cooling
All on Watercooling HERE IS A PICTURE
Ok so here is the issue as it stands. I have just tested both sticks individually in SLOT A and they are fine. When I try to put one stick into SLOT B by itself the system will not give me video but starts up fine. If I put a stick in both SLOT A and SLOT B at the same time, the system boots fine.
Does this sound like a dead RAM slot on the motherboard or a Problem with the CPU's memory controller?
How can I be sure as it would be a real pain in the ass to take everything apart if it is not really the motherboard with the issue.
General Crespin said:
I might be missing something, but does this happen with other RAM?
I have not tried other RAM yet as I tested the sticks individually and they were working fine. I could try that later tonight i guess.
