Random Screen Blanking
The fact that it 'comes right back' is weird. Try swapping the monitor or the monitor cable to rule those out.
Also since you are using Win 7 .. does this happen in WinXP or Vista?? If not you know the problem is Win 7
Sounds like a display link negotiation problem.
Possibly you have a bad connection on the video cable or the cable is faulty.
Try another cable.
Its also worth trying 60Hz, 65Hz and 70hz refresh rates.
This wont cause any damage and may work fine for you.
i think it has to do with the TDR problem some people are currently having....myself included.
Basically your driver is timing out then recovering. This is happening most noticeably on nvidia chipsets with nvidia cards in win 7.
to be fair i didn't get it on my 680i and i only get it on my 780i when using sli. i would good that problem though and see if you get any answers to your issue.
